Another tip to note here is how you actually use the lever to engage the gear you're downshifting to. For the smoothest and lowest effort engagement, try the following (4-3 downshift example):
1. Lift and declutch, push lever out of 4th into neutral (fingertips or open palm, easy movement, hand stays on lever)
2. Blip throttle (blip should bring engine speed above matching speed for 3rd engagement - you figure this out by sound, feel, experience, etc.)
3. Push lever towards 3rd until you feel synchro engagement (fingertips or open palm)
4. Increase pressure until revs match and the lever slips into gear (heel of your palm)
5. Release clutch smoothly (a subject in itself) to complete the shift.
This method is in opposition to simply pushing the lever straight through from neutral into 3rd. The brief pause against the synchro assures the speeds are matched and wear is minimized, as well as smooth engagement.
Paul B. Anders / Phoenix, AZ
1970 Porsche 914 / 2003 Porsche Boxster / 2009 Honda Fit Sport Auto
