Old 01-20-2009, 11:38 AM   #12
stephen wilson
Shifting into neutral without the clutch won't hurt anything as long as there's no load on the transmission from either acceleration or deceleration. You actually don't need to blip at all for the 1st downshift. For example: cruising in 4th with light throttle, lightly "preload" the shifter towards neutral with your hand, lift off of the gas, and the shifter will pop into neutral when the load is released from the engine/transmission.
Steve
