Top Dash Light
Dear Sir, thank you for your reply but I have test the clamshell micro switch and it tests ok. I even put a small piece of rubber on the clamshell where it contacts the switch to make sure that it is pushing it down and it definately is. The B - Pillar micro switch also tests ok as does the top latch switch. I have taken the control module out and cleaned the contacts and "tapped" it like has been described in other forums but nothing will turn the dash light off. I am at my wits end. Do you think I might have a bad control module?? Thank you very much, Jerry
