It's waay too early to be thinking about engines and clutches... it's just a low coolant light.
Could be anything from a bad hose clamp, cracked coolant reservoir, a leaky radiator, a bad hose, a failing (weeping) waterpump, a head gasket, to simply being low on coolant.
Have it inspected and pressure tested and bled (maybe even have the coolant replaced w/ that many miles on it if it hasn't been done before) - how old is the car? - you may be due.
