Old 01-17-2009, 07:25 AM   #1
mikefocke
No way to tell
Buying a car that has 106k miles you expect a flaw (or you get a pre-purchase inspection by someone who knows the cars). That is why it was priced the way it was.
So what to do now?
Look at the oil on the dipstick and see its color...if milky you have real problems.
Fill the coolant tank in the rear trunk with water to the line.
Drive till things are warm (showing 170).
Let it cool down and see if any leakage has occurred. What is the water level now?
Oil/Coolant tank? Water pump (more common)? Fill pressure cap? Hole in radiator (you have at least 2 of them in the front corners of the car)?
If you can't pinpoint an obvious leak, get it to a Porsche mechanic who knows how to burp the system and pressure check the system.
This needs to be fixed now.
