Old 01-16-2009, 02:14 PM   #2
sb01box
thanks for the input.
the only two times that I miss-sequence the top down order are the only time that this lockout occured.
i was wondering if the electronic brain had some lockout feature..
as for the switch, does the plunger get pushed in when the brake is released and if so, then the internal spring pressure is use to push the plunger up when the brake lever is pulled?
tried to see if the situation cleared up after 4 hours... no luck this time.
will be taking the center console body off
sb01box is offline   Reply With Quote
