Old 01-15-2009, 07:32 AM   #1
Christian H
Christian H's Avatar
Originally Posted by trieullionaire
Here is the LED lit door handle in use. I used the 3 inch white led strips and wired it up to the door lights. It's great, when you unlock your door the light turns on and when you lock it, the lights fade off. A nice modern safety feature to add on for those of you who are techies or gadget geeks like me.
Where did you connect to the door light wires, in the door or did you run the wires into the car ?Also did you drill through the handle to pass the wires into the door?
Looks good.
Christian H is offline   Reply With Quote
