Originally Posted by pchase
OK, I just checked and it is definitely a stock shifter. Also, while jiggling the shifer, it seems like the stiffness is coming from the cable (or tranny I guess) itself. Do these cables go bad?
I don't understand. I wouldn't think there would be any cable pull under side to side motion, just up and down motion through the gears. The cables are attached to the bottom end of the shifter via a ball and cup. You might want to see if there is some binding there.
