Old 01-14-2009, 08:53 AM   #10
Burg Boxster
After going thru the whole evaluation process and trying little torpedo units, etc, I decided to go with this and finally have a heated garage!
Reznor UDAP45 - 45,000 BTU Nat Gas unit:
I looked at the Hot Dawg (too much $ for what it is), Mr. Heater (can buy thru Northern Tool - great value - but read more than a few complaints about fan noise and mis-fires/no heat) and Reznor (known leader in industry w/ great warranty on unit - parts/labor and heater core/burner unit). Picked it up for ~ $530 + tax (since it was local). I almost bought it from an outfit in IA which had a special of $518 but w/ frt to me, it would have been same/more than local. Since your in IL you might want to check them out: http://www.denniscoinc.com/special.pdf
I looked hard at IR units but the recommended min height was 12-14' and mine is only 10' and w/ 700+ sq ft, it would have required multiple tube runs which I did not want.
Good luck!
