Don't start it up as you'll just put more wear on the engine from a cold start and introduce a lot of moisture into the exhaust system.
I'd really recommend either disconnecting the battery and removing it from the car or charging it on a regular basis. The battery will last a lot longer and you won't get a bunch of corrosion spreading out from around the battery terminals to the cables and the surrounding area around the battery. I use a Porsche battery tender device that I bought used for $50. It plugs into the cigarette lighter socket and automatically maintains the battery.
Dave S.
2003 Boxster S
