Old 01-13-2009, 02:29 PM   #10
cvhs18472
If you put on equal spacers front and rear thgen the steering will remain as it is--neutral: if you put smaller spacers on the front and wider on the back it will affect your steering geometry. I originally had 7mm on the back alone and it felt different. I talked to my supplier( Sunset Auto) and he explained the problem. I put on 7mm on front and all is well. Do not sleeze out and use the original lug bolts, even 7mm spacers need longer bolts. Ed
cvhs18472 is offline   Reply With Quote
