Yes, definately pull up the boot and see if it has an aftermarket shifter in it. My guess is you do and it's not adjusted properly and there is too much tension on the bushings. As Tamarsha said the aftermarket shifters have an adjustment where you can put tension on the bushings whereas the stock shifter does not.
