Originally Posted by superglide
LB,
Finally!! It took some circular-searching, but I finally found your answer to what has been my latest project research. I am good to go now.
One question, though; out of the specified 9.5 qts that this trans is said to contain, how many qts of new fluid did you end up replacing? I ask this as I'm still trying to find out what amount remains in the trans after the filter change, etc.
Many thanks for all of your technically aware information.
Andy
IIRC I got a little more than 8 qts. in. I had a leaky gasket which was why I went ahead and did the change. Since there's no dipstick, it's not easy measuring what I may have lost and since the pan had to come off anyway, I went ahead and swapped the filter too - it's right there. I bought 10 qts. of ESSO and opened 9. It was overflowing as I got the plug back in, but 8+ went in.
