Old 01-07-2009, 11:21 AM   #3
ChrisZang
ChrisZang's Avatar
I had the same problem and ended up buying a new belt
Hopefully you can find it locally as shipping charges are outrageous (due to the charge in the tensioner it's "hazardous material")
When you swap the belt (which is fairly easy) make sure you have the battery disconnected for AT LEAST 15 minutes !!!! Otherwise you will get an "airbag idiot light" for which you either need to go to Porsche to get it cleared or you need a Durametric.
