Originally Posted by aramati
I recently took my Boxster S on the track in Pahrump. There were 2 indentical BMW's M3 Coupe with the 330 HP engine. The three of us were in the same class(Beginners); so we got to see how both cars behaved. It was real strange, in the corners, I would really gain grounds while in the straights I would loose it. At one point one of the BMW's feeling my heat behind it, spun out of control and went off the track on a tight turn; it was sweet. The other driver with a bit more skill, stuck to me like glue. The moral I think:
A Boxster with a 250HP is better than an M3 Coupe with 330 HP. I just love the way the S take the curves on the track and brakes off speed. At the end of a straight and before a 90 Deg turn, my speed was at 105 MPH, the car brakes and suspension, made it look easy. You just cannot get into trouble and if I did, lifting the foot off the gas a bit corrected things quickly.
I think if I had more HP without beefing up brakes and suspension, I would get into trouble coming out of a straight into a tight turn. The car as it is is very well balanced. Why fool around with a good thing?
I was watching the Valvoline Run Offs a couple years back(the year Saucier had his controversial win) and the little Miatas were outpacing many higher horsepowered cars. Cars like the Integra would close up the gap on the straights but the RWD Miatas would lose them in the turns. I guess it hold true at the lower end of the HP spectrum as well.
