Old 01-07-2009, 12:32 AM   #3
fragdude
There is a way to open the front trunk by pulling on the manual release cable in the front drivers side wheel well. once in the front trunk you can unplug the battery. Wait 30 seconds then plug it back in. I would think this would reset the keyless entry.
http://mike.focke.googlepages.com/whenyourbatteryisdead
"Another method is...Inside the top of the driver's front wheel well, just aft of the spring coil mount, is a little rectangular corner in the black plastic shroud that lines the inside of the wheel well. Reach under this, and you will feel a "wire" about 1/8" in diameter. Too thick for an electrical wire (and not in a harness anyway). Tug this cable gently out from behind the shroud and get a good grip on a loop of it. Now pull hard away from the headlight once, and prepare to hear the music of the alarm as the front hood pops open."
OR if you wanna be really BA, take your shirt off, wrap it around your hand and punch out one of your windows. If people are around this makes you look awesome....stupid, but awesome.
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
