Originally Posted by stateofidleness
aww man are you serious?!
damnnn i just had my coolant system fixed along with a flush and all new coolant...
there's no way around not having to flush the coolant?
thanks for the info. do you think if i went to the dealership tomorrow, that they would have those 2 parts on hand?
Well, The only things above that coolant level of that plate (because it's located on top of the engine) is the burp tank and oil/coolant heat exchanger. So I suppose you can put a drip pan on the floor in front of the engine and take the mount (cover) off and let the system drain down to it, then just refill what came out.
