If raising/lowering it several times does not work. Try lowering it and holding the switch for 10 seconds after the windows is all the way down then raising it and holding it another 10 seconds after the window is fully closed.
I had the same issue after disconnecting my battery and remembered reading somewhere on the forum about doing one or the other for several seconds so did both for 10 and it reset my windows.
ian
- ian
