I suppose a wheel bearing could be the culprit, but that would have to be one bad bearing (and you'd probably be hearing a drone or dull whirring sound).... as a sanity check before anymore freeway driving, jack up each corner and grab the top and bottom of each tire and push/pull hard to see if you can detect any play from the hub (also known as 'wheel bearing carrier').
good luck,
kj
