Old 12-28-2008, 02:23 AM   #17
csu15919
Originally Posted by superglide
LB,
Great forensic analysis! It had to be an event of that magnitude, to beat up those plugs in that manner. But why would someone with all of the stated problems, prior to the muffler upgrade, even spend the bucks on the new muffler; while, to use an historic analogy, "Rome is Burning"?
sometimes, it's even difficult for me to determine a method to my madness. if you took at peak at my previous threads, you'd probably get a better understanding. the muffler purchase was actually to solve another issue as opposed to just an "upgrade." anyhow...for those that were interested (geez, this was a long time ago), the problem was solved. i believe i started another thread...but in short...my motor was bad. i dropped 2 valves (more than likely caused by a mis-shift), which destroyed the piston & liner in that particular cylinder. lesson learned....BE CAREFUL SHIFTING AT HIGHWAY (high rate would be a better term) SPEEDS.
csu15919 is offline   Reply With Quote
