			I had the same problem and swapped out the drivers door lock assembly.  I did some investigating and found the micro-switch that works the window drop with the door handle.  The switch is below the lock and upside down and I found that the switch (with a plastic plunger) was dirty and didn't have any lube on it and was worn to a point that it didn't operated the micro-switch.
 I'm now going to keep the mechanism clean and lithium grease applied to those contact points.
				__________________Sadly on the outside looking in.
