broken clamp on lower hose for AOS
Great write up on the AOS. While removing the lower breather hose (not the accordian one) from the AOS I broke the clamp not realizing it is actually part of the hose! Now that the AOS is back in I cannot trace the hose to where it ends.
Is this a hose that I can replace somewhat easily if I remove the AOS?
Is there another fix for this clamp where I wouldn't need to replace the hose? It seems a daunting task.
Thanks!
