Old 12-18-2008, 03:55 PM   #13
fragdude
K&N does have a very firm stance about their filters not causing MAF problems due to the oil. Someone, however, did run a test on the filtration performance of aftermarket and stock filters here:
http://www.bobistheoilguy.com/airfilter/airtest1.htm
I haven't read it again, but I believe the conclusion was that the stock filter was more restrictive but cleaned the air better. Maybe this is the cause of the MAF problem? maybe the Outerwear pre-filter helps the filtration enough that it doesn't matter? All I can say is yes, it would be really nice if you could just open up the side vent and change the filter
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
