Thread: Boxster parts
Old 12-17-2008, 07:21 AM   #3
Lucky
Originally Posted by djjohnj
I am not as concerned with the sanctioning bodies rules at the moment. I am just trying to understand the interchangability of parts.
So will the 6 speed bolt up to a 2.5 without too much work? If so what else needs to be changed? Are gears readily available for the 5 speed?
Good question. I'm not sure if it bolts straight up or if some form of adapter plate and different mounts would be needed. My hunch is it should be quite possible to put the 6-speed from the S into a base boxster, however it will be much easier to source an LSD for the base boxster tranny. There is an active group of racers that are developing a Spec Boxster series -- I think you should call the shop that is leading the effort as they will have the best intel on racing parts for base boxsters. Take a look at: http://www.boxsterspecracing.org.
-- JB
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
