If you use a dock connector the audio adjustments on your iPod will not affect the audio going to the stereo, and you use your stereos volume to control it. Because of this you don't need to worry about you're output volume affecting sound quality which can be a problem with the 3.5mm connection. (For example if you turn your iPod all the way down and your stereo all the way up, it will sound horrible.)
