Old 12-11-2008, 05:19 PM   #11
CJ_Boxster
Send a message via MSN to CJ_Boxster
If you use air to push the fluid out of the system, you will need a PST II/PIWIS unit to cycle and reset the ABS system after you refill the system. The object of the Motive unit is to push out the old fluid with fresh, so you don't have to use the factory/dealer diagnostic computer to get the air out of the ABS valves and pump.
Only issue with using the PSTII for the ABS flush is that you can only have the PSTII actuate the ABS for only 15 seconds at a time or else it burns out the ABS unit.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
