Thread: iPOD AUX
Old 12-09-2008, 11:26 AM   #11
blue2000s
Porscheectomy
Originally Posted by quietcoolone
Many of you using the BLAU/8-pod or BLAU/8-3nput may still be able to use them to play the new iPod/iPhones released September 2008 but should know that these will not charge. Apple decided to change the way these iPod charge by switching from 12V FireWire to 5V USB.
So, if you purchase one of these new iPods (iPhone(3G), Nano(4G), iTouch(2G) you will have to charge them elsewhere or update your dock connector to one that supports 5V USB Charge.
Peripherals just released the IS75 (Audio) and IS76 (Audio/Video) adapter cables and it appears that these cables will charge both new and older iPods/iPhones.
The problem is that these adapters terminate in RCA plugs instead of the 8-pin plug that fits the aux input on the radios .
Two separate parts are required to complete installation:
BLAU/8-RCA
http://www.discountcarstereo.com/detail.aspx?ID=288
IS75 or IS76(PXP01V)
http://www.discountcarstereo.com/detail.aspx?ID=896
http://www.discountcarstereo.com/detail.aspx?ID=1299
I recommend the IS75 because it has two inputs;
A 3.5mm (1/8" jack) for an MP3 or SAT Radio etc
and the dock connector for iPod/iPhone
That's interesting. The iPod could always be charged through USB 5V. The iPod doc interface carries both 12V and 5v input. I didn't realize the 12v could also be used to charge the iPod but it makes sense that that's what automotive based chargers were doing. Now we'll need a 12-5v transformer and wire up the the 5v pin in the doc connector to charge in the car, which presumably is what the two cables you linked to are doing.
http://pinouts.ru/PortableDevices/ipod_pinout.shtml
Another alternative would be to buy an older iPod for listening to music in the car and continuing to use the 12v charge port. The early touch wheel iPods are not very expensive anymore.
