Old 12-02-2008, 03:00 PM   #5
Adam
Originally Posted by bmussatti
IIRC, our 987S's are right about 11:1.
I think you're getting the compression ratio mixed up with the air/fuel ratio. An 11:1 air/fuel mixture is extremely rich and the engine would run very poorly. Optimum A/F mixture is around 14.7:1. Eslai, you should definately get a tune done, you'd probably pick up a nice amount of hp and improve the curve even more as you suspected. The computer doesn't richen up the A/F mixture if you run low octane, it just pulls timing so the 91 oct gas isn't why your A/F is rich. Your engine is definately not running at it's peak at 12.5:1
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
