Old 11-26-2008, 08:57 AM   #4
Kirk
Originally Posted by chitowndad
Kirk,
What's involved in replacing the springs? I've got a spring compressor but I've never actually done spring work. What other parts would you need to replace the springs?
-Steve
Basically you have to remove the front and rear shocks, compress the springs, take off the spring hats, replace the springs, replace the spring hats, replace the shocks.
Some folks use a special tool to break the ball joint at the bottom of the hub and remove the whole front hub to get the shocks out. Why they do this is beyond me as there is a MUCH simpler way to do it. The front shock removal is actually pretty easy and I can provide you with a link to the easy instructions that are on Renntech.
The rears are a little more difficult, but again there's a short cut way to do this. It involves taking out the camber bolt, so you'll screw up your camber setting unless you mark it. But that's really a non-issue as the car will need to be aligned after the spring change any way. Again there are instructions on how to do this on-line.
So long story short, the only special tools you need are a spring compressor and 7 mm allen wrench (not a common size). The allen wrench is for holding the shock shaft while you remove and reinstall the spring hat. I found a 7 mm at my local auto parts store, but it was not in my standard allen wrench set. You don't need other special tools than this if you simply take some of the short cuts which actually make the job MUCH easier any way.
Now if you're asking about parts and not just specialized tools, well with the Gemballa springs you don't need anything more. The Gemballa springs are sized such that they're just a drop-in replacement for the stock springs. You still use the stock OEM mounting hardware, bump stops, spring hats, etc.
I'll PM you about the speakers.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
