Old 11-22-2008, 08:44 PM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
Setting up your phone to work through the stereo is really complicated and expensive. Basically, you have to dismantle the instrument cluster to mount a mic, wire the Becker AUX, hookup a mute switch relay, then hook it up to a 2.5mm phone jack.
I can explain in more detail if you want but I would recommend a bluetooth headset or visor mounted speakerphone, it will be easier and cheaper.
