Originally Posted by brp987
pardon the hijack, but in the process of putting in a rear wheel bearing, on my '01 S. I measured my rear disc and it was 22+ mm. Do 'S' and base use the same discs? The bentley makes no such distinction. Did a previous owner put front discs on my rears? Weird.
The Base and 'S' do not use the same discs. The discs on the 'S' are 318mm (f)/299mm (r) in diameter vs 298mm(f)/292mm(r) for the base.
Also, new the 'S' rotors are 28.0mm(f)/24.0mm(r) with wear limits of 26.0mm(f) and 22.0mm(r).
