Originally Posted by litteng
is thisthe same for the cdr24 ?
Is what the same? That the radio does not require a code? Yes, the CDR24 uses the MOST Bus and while there is a code, it is not asked for, nor can it be set by the user.
This requires the PST2 or PIWIS Testers which pretty much only the dealer has. If you disconnect the battery, you won't be asked for a code once you reconnect it.
