Old 11-15-2008, 07:56 PM   #4
JFP in PA
If you use air to push the fluid out of the system, you will need a PST II/PIWIS unit to cycle and reset the ABS system after you refill the system. The object of the Motive unit is to push out the old fluid with fresh, so you don't have to use the factory/dealer diagnostic computer to get the air out of the ABS valves and pump.
