Old 11-15-2008, 02:28 PM   #1
986Porsche986
Brake Fluid Flush Question
I found this post on the forum.
http://986forum.com/forums/attachment.php?attachmentid=8831
According to this tutorial, you are to use the empty Motive to push ALL of the old fluid out of the system and into a waste bottle at the rear right bleed valve until you hear the sound of gurgling air coming out of the valve. Wont this method allow air into the system? I have read other posts where this method is also used, but just enough to only lower the fluid in the reservoir to just above the sensor, then start bleeding with a filled Motive pressure bleeder. Can any "experts" chime in and let me know if the method in the attached PDF is incorrect? Thanks.
986Porsche986 is offline   Reply With Quote
