Originally Posted by dcdrechsel
Thanks for the tip .I was thinking that they could be a more cost effective solution for my squeeky front end .
Hmmm... I would question your reasoning there man. You might want to research polyurethane bushings a bit more. See they're stiffer than the stock rubber parts and don't give as much. This makes them better/more stable for racing applications or general high performance. But one downside to PU bushings is that with them being stiffer they don't give as much as the stock rubber parts and actually SQUEAK a lot. In fact they give you a special lube with the PU bushings to help prevent this squeaking. If you're trying to simply replace squeaking parts and don't need the extra performance, then I would maybe consider your other options. But hey, do a little Google search and see what you come up with, don't just take my word for it.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
