Old 04-06-2005, 06:56 PM   #4
mrmickeymouse
Shipping
Originally Posted by dennizxxx
if i have the halogen lights, can I simply swap the headlights or is there more wiring, etc..work to do..????
Also how much is shipping..??
There is a wiring harness for the "full" effect of Litronics, if you skip that [I did] you will get white light, which at night, not only is very effective, but looks really cool - The best part in my opinion. It reminds me of the search lights you see in the night sky. It is white.
The harness gives you an additional distance of lighting. It will work just fine without the harness, the only caveat is that you will need to pull your headlight fuse[s] and put heavier [by 5-10 amps] fuse[s] into the slot[s].
This is all covered in the Porsche TSB, which I will send you upon request.
BTW - I need your zip code for a shipping quote.
Thanks,
Scott
mrmickeymouse is offline   Reply With Quote
