Old 11-07-2008, 10:45 AM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by TheGoose
CJB - what other symptoms did you have before replacing the AOS? I have smoke at start-up and a bunch of other problems that may be AOS related. When cold, the car has no power and it stalls/backfires badly with acceleration. Only when it's warmed up a bit does it come get a little life? I've "cleaned" the MAF with no luck. The problem started slowly over the last few weeks and is pretty bad now. My nearest shop is 4 hours West! Any ideas?
Hey Goose, I had those same problems early on as well. Before replacing my AOS i went ahead and bought a new MAF and that fixed the weak cold engine issue but it still wasnt 100% when cold. After replacing the AOS, the cold engine power was back to normal and my idle was perfect and didnt hunt around when my AC was turned on.
'FYI I had to replace my new AOS twice, The first one still caused puffs of smoke and the idle steadily got worse, the second AOS actually sounded like it had a 9mm bullet firing out of it and my idle steadily got worse. Of Course the dealer gave me new AOS for free since this is a defect in the AOS they giving me so keep a close watch on my AOS for oil leaks and little bits of exhaust smoke cause you may get a defective unit and you can only replace it free if you report it as defective 30 days from purchase.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
