Old 11-06-2008, 04:50 PM   #3
Burg Boxster
As long as it's threaded straight and tightened (hand tight to stop) then no issue would not be torque. Just in case, you might want to have your girlfriend/wife/partner tighten it down for you j/k
Looks good to me, except all coolant below. Without residue on bleeder valve I definitely suspect it's the cap leaking it. Get a new one and it should solve your problem. If you buy from local dealer it'll probably run ~ $35. If you buy online from Sunset or Suncoast Porsche it'll run much less (it was ~ $15 in '06 when I replaced mine).
BTW, what does your cap look like underneath? Like the one on the left or right from my pix above?
