I can't see how mounting the charger would hurt anything, (except your 0-60 times due to 1/2 pound extra weight). Some chargers are designed to permanently attach, you see it done in boats way more than cars. I'm not sure why you want to make it permanent, I think the more important issue is whether the unit is a float charger which automatically ceases when the battery is at peak then resumes charging only after a given amount of battery voltage drop. I leave the float charger on all winter, never had a problem in many years of doing so.
