Originally Posted by macyfilms
I connected the posts at the starter/solenoid and the engine cranked like a champ.
The history:
Battery: replaced AND charged for 24 hours.
Ignition switch: replaced.
Clutch switch: checked, appears to be going in and out and clicking accordingly.
Fuses: all appear good.
Relays: seem okay. switched out relay with same #, still no crank.
Immobilizer: opened box under seat; no obvious sign of any damage of any sort.
Starter: tested, spins fast.
Solenoid/Starter: Cranks engine hard and fast.
Analyzer readout: no problem codes.
Key: appears good; "capsule" inside appears fine.
Sorry I missed that part. Sure sounds like an immobilizer problem.
