Old 04-04-2005, 11:18 AM   #2
RandallNeighbour
While it could be a faulty switch inside that hole, it's more likely to be an issue with the hook and you!
Before you latch it shut with one hand, use the other to insure the hook is fully over the hole so it doesn't catch the edge, but go in as far as it can.
This is a common problem with my Boxster... the top is old and it doesn't want to close completely on its own. I guess that's why the hand pulls were put on both sides of the hook mechanism.
