Old 10-22-2008, 03:44 PM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by Brad Roberts
-New Adjustible Front Upper Control Arms
-New Adjustible Rear Upper Control Arms
Can you explain this a little better? I have someone interested in the car, but so far, NOBODY he has spoken too can figure out what "new adjustable Upper front control arms" are, and that includes ME
Bottom line: did you install GT3 front arms on all four corners?
Also: WHAT shocks did you use when they where replaced?
B
Attached below are images of which control arm is replaced with Adjustibles... They mount to the Lower control arm then mount forward to the chasis of the vehicle.
All 4 corners were replaced
The third & forth pictures are of the actual adjustible control arms.
The struts were replaced with OEM Porsche Struts, not Bilsteins or Aftermarkets.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
