Old 10-19-2008, 06:41 AM   #1
Jaxonalden
Jaxonalden's Avatar
Driving it will only result in a pop and fart, you'll be alright. Call Autozone first to see if they can hook up and read your codes.
About your tubes...Wheew...you pulled the coil packs and thought the tubes we are talking about came with them, no they didn't. They are part of the ignition system, they transfer the energy to the plug from the coil pack. The tubes are still installed, you need to remove the spark plugs and then you can remove the tubes. I don't know if you can just grab them or need a special tool to insert, expand and pull the tubes out.
I feel so much better now!
