OK 986FortyEight, you being nervous is making me nervous so I did some research and will post a new thread with what I found. If you go to You Tube and type in the search for Porsche Boxster S Engine Rebuild a group of 5-10 minute rebuild clips (about 15) will come up and if you select #10 they are putting the head together and it shows the spark plug tubes going in with the O rings installed.
I hope for your sake the O rings were not installed but I highly doubt it. BTW, this series initially fixed the problem of a crack in one of the spark plug seats by getting it welded and machined.
