Originally Posted by 986Porsche986
Ok, so I bolted on the exhaust and went for a run. It sounds amazing, with just a little bit of resonance only when I punch it while I am in the 2k to 3k range. If I am just giving an even amount of throttle in that range, I really dont hear any. It does seem like the car is a little bit slower and not as responsive. I am going to run it for a week or so and see if the computer adjusts. If I dont notice a difference, I will reset the computer and see if it can adjust to the new changes. Has anyone else noticed this?
I felt something similar... Then I reset the ECU, and ran it hard... Felt faster after the ecu reset... I'd give that a try asap!
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
