Old 10-15-2008, 03:25 PM   #1
blue2000s
Porscheectomy
Originally Posted by porsche986spyder
Okay, but is there a dip stick like there is for the regular oil checking? Or is it just a visual container like the brake fruid area has that you can see clearly where to stop because the container is clear plastic and has markings? Is it at least reachable in the service mode? I have the Bently manual at home. Guess I will look it up when I get home.
No to all of those questions. You have to make your own dip stick with a hanger or something to reach into the hole to see what the fill level is. And it's all done from under the car, you can't change the transmission fluid from above. Although you could fill it by adding oil through a hose, I suppose. I just use a hand pump with a 1 quart capacity.
