Originally Posted by Richard Truss
i will check all those things. i know the air filter is due to be replaced and i have not checked my tire pressure for a while. i just got a new MAF -- is that the same as the O2 sensor?
as for oil, i am currently using mobil 10/30 -- would that be the correct weight?
No, the O2 sensor is different sensor. Sits back of muffler. If it were bad, you would get a code.
Re: Oil, manual recommends 0-40 Mobil 1, which I would certainly recommend in your Vegas summers. In winter you could get away with the 10-30 Mobil 1.
Another alternative, which is less expensive, is Shell Rotella T, full syn. 5-40W. Run it all year long.
Wally World at $13.50 per gallon.
