I have a short shifter fitted which has the standard shape shaft. The inside of the gear kob is round.
This might bring a tear to you eye, but I epoxied the knob on! The shifter was only £50 and it isnt likely to wear out, and I figured that there's no need to ever remove the knob anyway, as the centre console can still be removed with it in place.
The only major hassle I had was that the hole in the knob is about 1mm smaller than the shaft thickness - so had to grind 1.5mm off the shaft for the knob to slide over, which was a right PITA.
