Old 10-09-2008, 07:20 PM   #10
Jaxonalden
Jaxonalden's Avatar
Cjweiss,
You should be able to troubleshoot this down to the system. I'd love to draw this out in a trouble tree but this should work;
First, does it turn over? Yes, do you have spark? Yes, do you have fuel? Yes, do you have compression? If you have all of those the car should start.
No to the first using the starter, push it and stick it in gear and see if the engine will turn over that way...if not, its locked up and its time to cry. No to the second on all cylinders, possible ECU failure (its not telling the plugs when to fire). No to the third, check your fuel pump for power (not running?, fuse). Good?, check your fuel filter. No to the fourth, possible skipped timing but doubtful.
BTW, what part of the land of cow **************** and beer farts are you in? I'm from 100 miles north of Green Bay and a die hard Packer fan and shareholder.
