Thread: Kirk's Ride...
Old 10-07-2008, 10:47 PM   #104
Kirk
JRZ Shocks Done
Finally got my JRZ coilovers done! What a royal pain in the ass! In the front I got the front remote reservoirs hard mounted (no more zip ties) with some custom brackets and I had to remove the shocks again (3rd time) to get them shimmed up a little more. Fit seems to be just about perfect now, ride height is set, and alignment is near perfect (still needs some toe work though). I'm running about -2.3 degrees camber with the camber plates. Only down side is that the sperical bearings in the camber plates are damn noisy. I'll have to get used to that.
Here's the new reservoir mount in the front:
The rear shocks turned out to be a lot more work than what I had expected. It turns out that you can't get the reservoir through the shock mount in the wheel hub because the drive axle is in the way. The solution? I had to remove the rear axles. The only problem is that they're held on with 340 ft lbs of torque. I could NOT get the nuts off the axles. I thought maybe a local shop would loosen them for me, but I second guessed that as I doubt anyone would let me drive home with loose axle nuts. Finally, as a last resort, I borrowed an impact socket, 3/4" drive breaker bar, and 4' (yes four FOOT) cheater bar from the millwrights at my work (they work for me, so I get some special treatment). I got the nuts off, axles out, shocks in, and remote reservoirs run to the rear trunk. Then I used a HUGE torque wrench from my work to get the axle nuts tight again. All in all it took two weekends of work. The car is way too low now, so I still need to raise it up more. It's a bit of a game though as the wheels can rub on the outside fender and can rub the coilover adjustable perches. I need to raise the perches just enough to get them past the rub point. The 275 mm tires on 10" rims are just pushing the absolute limit of what can fit. I'll go to 265 mm tires once these wear out (too soon I'm afraid). I'm running about -3.0 degrees camber in the rear, but I haven't done an alignment yet.
Here's the remote reservoir mounting in the rear trunk:
I won't really push it until I get ride heights set better and a more thorough alignment done, but some quick test drives have suggested that the car is now unf_cking believable. It corners so damn hard and fast that it will make your neck snap. It is just totally insane for public road driving as the limits of adhesion are so extremely high and I've still got the shocks set to their softest setting. I have GOT to autocross this car can take it to the track!
I'm also working on a nitrogen setup. I've got the valves, gauges, regulator and tank. I've just got a friend making some custom hose for me. Then I'll be able to adjust the nitrogen pressure to get the ride stiffness where I want it.
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
